Everytime i export a CAD model into sketchup it ends up having extra lines on the surfaces of the model. Is there a way to get rid of them in sketchup? thanks
pretty late, but when you import, check the option for 'merge coplanar faces', or if you have sketchup 5 just right click the object with the problem and 'merge coplanar'
5, that's great advice. I had same problems earlier, and end up erased all the lines. It will be quicker to creat those walls directly in sketch up. I will try your suggestions out. Thank you!
CAD to Sketchup
don't know the precise answer, but you may find what you need here: sketchup faq's
those are acad's polygon lines -used to create 3D faces. i do not believe there is a way to get rid of 'em.
but, of course, you can erase them from sketchup.
are they within a group? if so you have to double click the item to enter the group, so you can assign materials.
