help: translucence glass/acrylic
ht
anyone knows any low cost subsitution for translucence glass that's noncombustible (not ignore at 1200F)
Aug 25, 05 2:41 pm
try contacting the people at Lightblocks (www.lightblocks.com) they might either have something or be able to point you in the right direction.
Aug 25, 05 2:56 pm  ·
el jeffe
why non-combustible?
Aug 25, 05 3:00 pm  ·
JohnProlly
Low cost = prolly not fire rated.
Aug 25, 05 3:02 pm  ·
JohnProlly
I am a fan of Lumicite and different forms of polygal
Aug 25, 05 3:03 pm  ·
3 form
http://www.3-form.com/
Best material I've seen, dont know if its cheaper than glass though
Aug 25, 05 3:07 pm  ·
their eco-resin is good for leed,
and you can make patterns and sandwich them inside the material
Aug 25, 05 3:08 pm  ·
I035PEP
Polycarbonate, try looking at Polygal and GE Plastics.
Aug 25, 05 3:16 pm  ·
ht
Thank you for all your input. 3 form products are really nice, but its self ignition temp is pretty low. polycarbonate(GE/lightbox/CPI) got appox. 1070F, which fall a bit short as well. perhaps, glass may be the only choice for noncombustable.
Aug 25, 05 8:21 pm  ·
OlDirtyArchitect
3 form will run you about $1500 for 3/4" thick sheet (4X8) that does not include shipping. I think their sheets that are 1/4" are about $900. No orders smaller than 1 sheet of 4 x 8. I wanted a product of theirs for a coffee table but $1500 was a bit more than I was willing to spend.
Aug 25, 05 8:35 pm  ·
3 form is nice indeed. it doesn't meet fire standards here unfortunately.
you are looking for something less expensive than glass?
Aug 25, 05 8:51 pm  ·
el jeffe
seriously - i'm curious - why does it have to be non-combustible?
Aug 25, 05 9:02 pm  ·
ht
it's for exterior wall.. code requires it to be noncombustible.
Aug 25, 05 9:05 pm  ·
el jeffe
so this is a skin and not an opening - right?
Aug 25, 05 9:35 pm  ·
use laminated glass with a colored inner layer
viracon used to have a product called opticolor that you could mix and match inner layer colors to achieve a fair number of different colors.
i do not know if they still support this technology, but someone out there must...
Aug 25, 05 11:22 pm  ·
for the plastics, consider the smoke problem that may be worse than anything else about them. some of the newer resins mentioned above have qualified as Type 1 or A materials.
Aug 26, 05 12:40 am  ·
ice9
if its for an exterior application, remember that resins and polycarbonates will yellow over time in sunlight. acrylic and glass will not.
Aug 26, 05 2:39 pm  ·
