Need help IDing this material
dan85
Hi,
I am currently putting in a bid and need help finding this material.  It's aluminum angle that has ridges on it to lock into special nut with also.
Thank you in advance.
Aug 23, 15 1:18 pm
What does the spec say? If it's not there, it's probably a poltergeist.
Aug 23, 15 1:34 pm  ·
I was also going to ask if there's a spec. If the spec is a bunch of words that don't reference a brand name product, trying copying and pasting a long section of the text into google and see if it takes you to the manufacturer's page.
Aug 23, 15 1:40 pm  ·
The bottom of a Baguette is usually a thin crust of hardened dough.
Aug 23, 15 1:46 pm  ·
That is an odd shape for tasty french bread. Definitively some poltergeist involvement in that bakery.
Aug 23, 15 2:49 pm  ·
BTW, who gets this detailed in their documents going out for bid? This is the level of detail you'd see on shop drawings, not the construction documents.
Aug 23, 15 7:49 pm  ·
Carrera
Of course a Baguette is a form of architectural convex molding and a term used today by the terra cotta suppliers, specifically sunscreens which are supported by aluminum components….usually a kit-of-parts. The striations usually imply a corresponding metal part with striations to make a nonslip nesting joint. Would think that the answer lies with that industry.
The second shape from the right is what they call a Baguette.
Aug 23, 15 7:58 pm  ·
quizzical
dan85 - why don't you just submit your question to the design architect ?
Aug 23, 15 8:12 pm  ·
