I'm wondering if there's a way to make 3d surfaces into flat, lasercuttable curves in rhino. I thought unrollsrf / smash would do it but it wouldn't do joined surfaces. I tried make2d but it doesn't look very accurate?
make2d is accurate to the view you're looking through.... if you want straight on shots make2d from anything but perspective.... thats the best way....
a different approach you could try is.... there is a program called lamina that basically takes an exported .3dm file and separates all faces and lays them out on sheets to be lasercut for you... ive used it with pretty reliable success in the past.
I've always just manually unfolded surfaces if they're planar. If they're curved, you'll have to unroll. But beware that if you have double curvature, they're non-developable surfaces meaning that they can't be unrolled into 2d planes.
I seem to have gotten myself into a lot of trouble... it's actually really really easy... I'm just kinda new at this.
I didn't want to trace it over by hand... I just have a bunch of planar triangular/rectangular surfaces as floor/wall and wanted to laser cut/score them so I can fold them with minimal gluing.
I ended up using unrollsrf (what I needed was to turn explode off) and then tracing the cut/score lines myself. It works pretty well.
Thanks everyone for the tips and software!
Dec 1, 08 9:05 pm ·
Rhino -> Lasercutter?
Thanks for any help!
explode/ unjoin, then unroll....or squish
There's also Pepakura.
i agree with link above, a great piece of software...
just use 50-80 pound foam and shape it.... unless you are looking to make a faceted dome or something thats clear....
post a pic and i might be able to help a bit in making it without using a laser.....
b
