health care architecture
adyaautari
hi, could you recommend me a health care architectural building that are not so big but uniquely shaped? I'm having quite a hard time finding the perfect one for my uni assignment, thank youu
Sep 22, 21 11:03 pm
When is your assignment due?
Good luck.
Sep 22, 21 11:59 pm  ·
adyaautari
thank you! it's due october 2nd, its quite simple actually, we're supposed to choose a healthcare facility and make a sketch+model making out of it, I'm just starting the first year btw
Sep 23, 21 9:49 am  ·
natematt
Weird shapes are typically at odds with strict programming requirements and really expensive construction. At most, they tend to compensate with size.
Anyway... you could do your own research, but I guess I'd mention https://www.cannondesign.com/o...Pretty oddly shaped for a healthcare facility, and not that large. Kind of the least interesting part of the design if you know anything about linear accelerator space planning though.
Sep 23, 21 2:01 am  ·
adyaautari
Thank you so much! it really helps. And for the context, the assignment is to make a model making of a healthcare facility with the area of the base 20×20, its quite small and to make a hospital that are commonly huge will be really challenging. By the way I'm just starting my first year :)) Thanks once again!
Sep 23, 21 9:59 am  ·
Maggie Center,they have around 30 facilities which are designed by different collaboration between architect and landscape architect. These small facilities are designed for patient with cancer. Every project has a unique or innovative point.
Sep 23, 21 10:55 pm  ·
adyaautari
Omg I think I found the one I'm looking for!! As you said, it has around 30 facilities and I'm interested in Kalida Sant Pau! Thank you so muchh
Sep 24, 21 12:38 am  ·
chopshop
To be clear, those are care centres and it looks like the starchitect buildings are a means of soliciting donations because they are largely privately funded. Not to dismiss its need or purpose but it operates differently than a regular run of the mill hospital.
Sep 24, 21 1:13 pm  ·
adyaautari
thanks for the info! I think its still eligible for my assignment since the typology of the building considered health landscape
Sep 25, 21 3:40 am  ·
Hospitals
Le Corbusier
Piano
Sep 24, 21 6:50 am  ·
adyaautari
thanks!
Sep 24, 21 10:09 am  ·
NBBJ had a couple projects they recently showed on their IG feed that might be interesting to you. Your post made me think of the Yellowhawk Tribal Health Center which takes on a different shape where the building is formed to create a small central courtyard. I also noticed their post showing the Meridian Center for Health. It looks to have a more typical formal layout though it could create a very nice looking model.
Sep 24, 21 11:55 am  ·
adyaautari
thank you so much! I'm considering them now, it really does look like it could be a c
ool model to make!
Sep 25, 21 11:09 am  ·
Pandekage
I used to work for HDR in their German offices, we have some pretty cool healthcare projects.
Sep 25, 21 2:48 pm  ·
adyaautari
thank you i just looked it up on the website!
Sep 26, 21 1:35 am  ·
