2-Story Porch Detail?
adt2
Hiya - longtime browser, first-time poster. My wife and I are in the final stages of designing our next home (we designed and built our previous home as well). The new place will have a covered balcony upstairs, directly above a screened porch downstairs. I've got the weatherproofing details (thanks, Fine Homebuilding), but I'm having a hard time locating or coming up with the exterior detail where the top of the screen porch meets the bottom of the balcony. Doesn't seem like it should just be a smooth plane - seems like there ought to be some kind of overhang, even if it's just a little one. Other trim details are probably in order, too.
Just wondering if anybody happens to have a detail of this area they'd be able to share (or a shove in the right direction if you know where to find some online).
Thanks in advance for your input!
Oct 17, 14 2:37 pm
chigurh
slap a 2x12 on it.
Oct 17, 14 2:49 pm  ·
Carrera
 Isn’t this it?
Oct 17, 14 8:07 pm  ·
chigurh
add more 2x12's!!!!  solid!!
Oct 17, 14 10:06 pm  ·
Everything you need to know can be found right here:
Oct 17, 14 10:13 pm  ·
awaiting_deletion
deadmau5 is asking - well, how many 2 by's you got under the 2nd story? Does it look like Carrera's photo?
Is the screen custom or purchased pre made?
I'd set is back a bit and get the maximum drip edge action going on.
Oct 17, 14 11:04 pm  ·
go do it
http://www.houzz.com/balcony-above-a-entery-porch
check out the 6th picture down
Oct 17, 14 11:29 pm  ·
Carrera
Go do it, that's it! Case closed.
Oct 17, 14 11:31 pm  ·
go do it
Just a heads up for the future. Architects don't design for free, even on forums.
Oct 17, 14 11:57 pm  ·
BulgarBlogger
Traditional homes make me sick
Oct 19, 14 2:13 pm  ·
BulgarBlogger
Wow... Just looked at your detail above more closely...
Your joists are end/toe-nailed to rim joists that are unsupported... The bearing surface of your post is under (2) 2-by's that provide almost no real support,,, unless this is a cantilever and the post is not steuctural.... I would really consult a professional before letting kids hang out up there...
Oct 19, 14 2:18 pm  ·
Carrera
The detail picture really isn’t a balcony – just was meant to show the arrangement of things, which is what I thought the OP was after.
Oct 19, 14 2:55 pm  ·
chigurh
I was being sarcastic...Like anybody could give the OP any real direction based on his generic description with no sketch....
put a bird on it!
Oct 19, 14 5:38 pm  ·
To the OP, just make sure you don't use a 1-story porch detail by mistake.
Oct 19, 14 5:52 pm  ·
awaiting_deletion
copy paste - oh shit...miles this could never happen.
Oct 23, 14 11:11 pm  ·
