Several days, I drove by chicago suburb and found there are alot of single house site on a small artificial hill. I just wonder what happened if those soil erodes after sth happened like flooding.
Does this kind of house still use similar size of footing if it is designed in a plain field? I guess at least deeper would be a logic solution.
Auger cast piles or even Caissons! I can't image they use this in Chicago. But if I build my house on the hill, these kind of foundation sounds logical to me.
The houses I saw have basements, this helps them to use less cost foundation too.
well of course auger cast piles or caissons would depend on the soil conditions and it's possible your concerns about erosion could be handled with a product like geogrid to stabilize the hillside.
I have a manual published by the university of Minnesota in 1979 called "Earth Sheltered Housing Design: Guidelines, examples, and references" that I picked up at a used book store that has great guidelines for just about anything you might consider of that sort.
I found this book. But it is more about under-earth building than building on the hill or slope.
I found there is a book called "Hillside Homes: 208 Sloping-Lot & Multi-Level Designs : 1000 to over 5,500 Square Feet". But I guess it just contains plans and eles.
Jun 28, 10 12:13 pm ·
structure for house in hill
in cali we do caissons to bedrock, baby ~ big bucks boo-ya !!
correct - typical spread footings do not work on steep hillsides. gotta go with caissons/auger cast piles. big bucks is right...
auger cast piles, but if designed right ya don't need tooooooo many.
i'm not sure, but i think you would use auger cast piles/caissons
Thanks farc.
Is ther any book talking about the structure for the house Being
built in hill/mountain?
mespellrong: Thanks for the recommendation.
All:
I think for Chicago and Midwest, I should use berm instead of hill.
hi, mespellrong:
