im having some problems when outputting drawings from illustrator or indesign to .pdf. the light lines (stroke .1pt or less) come out too dark, and i'm not getting the contrast that i want.
everything looks great when i view in illustrator or indesign, it's just when i print or save to pdf it looks like crap...i've tinkered with all the settings too: bumped up to 600dpi, 'view lineweights' in acrobat turned off, etc, etc....still no luck.
thanks Ivo, it seems it is just an image display issue in acrobat. i don't have a printer handy (on break from school) and will be sending these files directly to an online publisher, so i'm a little worried about the quality...i'll be leaving a lot to faith.
did it work out for you? did it look ok when you printed a hard copy i.e. same as illustrator screen quality?
765, it may be a scaling issue. these drawings were created for full format presentations, and now i'm scaling them down for a portfolio, so there are a lot of dense lines that look like single black lines when you scale them down (making them grey just makes them look like a single thick grey line). i gave them a .1 pt stroke, but the line weights don't look 'ok' until i zoom to something like 600% in acrobat.
im assuming there is a threshold of line thickness (or thinness in my case) that acrobat is able to read i.e. .25 pt
Print to a Tiff file usually work, although the file size can become very big. But this is a good option if your trying to preserve the lineweight you can see on screen.
You can also try to print to a pdf rather than exporting
adobe lineweights: making light lines even lighter
anyone have suggestions?
make 'em grey.
also, zoom in on the pdf, depending on the dithering, they might not be as dark as they look in preview.
When in doubt, go raster.
"did it work out for you? did it look ok when you printed a hard copy i.e. same as illustrator screen quality?"
It worked eventually and it looked ok and sharp on screen after rasterization but to be sure print your hard copies from the vector-based file.
i have had the same problem...when i need to print, i do so from illustrator or indesign and the lineweights come out fine.
havent found a great solution for preserving lineweights when going from illustrator to pdf though.
Problem with raster/bitmap images is that you can't scale them, change colors, etc.
Acrobat has some issues with display. I'd try transparent. It typically isn't a big deal.
