Laser cutting marble?
Do you know if it's possible to laser-cut thin sheets of marble or maybe another soft stone? or other veneer versions of similar natural materials ..If laser cutter can't cut it - what about water jet ?
can you get marble etc thinner than 3/8"
Mar 4, 08 8:05 pm
xtbl
pretty sure waterjet will do it. not so sure about the laser.
Mar 4, 08 8:08 pm  ·
xtbl
http://www.adv-laser.com/
Mar 4, 08 8:09 pm  ·
c
ooooh - thanks
Mar 4, 08 8:56 pm  ·
mespellrong
use a penumatic chisel
Mar 4, 08 9:02 pm  ·
farwest1
Seriously, waterjet cutting is as accurate as a laser, with no potential to burn the material. And it's probably less expensive than lasers.
These guys can cut anything: wood, stone, steel, foam, etc.
http://www.hydrojet.com/
Mar 4, 08 10:17 pm  ·
