Illustrator->PDF screw-up
randomized
hey,
do any of you have this problem that when you make your poster or whatever in illustrator and you make it into a pdf to show onscreen, so no printout, it looks horrible and all your delicate lines look fat and ugly? Some help how to solve this?
Sep 29, 07 11:30 pm
BabbleBeautiful
Funny I saw this post, I actually have the same issue when printing PDF documents from InDesign.
Sep 30, 07 4:42 am  ·
grid
when you zoom in they are normal... when you are zoomed out they look stupid... right?
Sep 30, 07 5:02 am  ·
rehiggins
I think that's just part of the compression and how Acrobat displays images. Have you tried "fullscreen" mode? Does it print OK?
Sep 30, 07 9:58 am  ·
randomized
My files print just fine, but when I want to send them to people on-line to review them (in PDF), even in fullscreen mode they look terrible and very unprofessional. There is no trick or illustrator function to fix it?
Sep 30, 07 11:14 am  ·
rehiggins
well, maybe actual image files would be more appropriate. on second thought though--are you formatting your PDF for screen or print (the settings for each are in the PDF printer)? The print version has a much higher resolution and may be why it looks wonky on-screen.
Sep 30, 07 11:17 am  ·
e
The has been a problem in the past. I recently purchased CS3 Professional that comes with Acrobat and it seems they have solved that it in the lastest version.
Sep 30, 07 11:44 am  ·
BabbleBeautiful
I have CS3 and I still have this problem.
It prints out what it shows in Acrobat. Am I missing a setting somewhere?
Sep 30, 07 2:06 pm  ·
e
Do you have Acrobat Pro? Maybe there is a distinction betwen the Pro and less robust version of their software.
Sep 30, 07 2:16 pm  ·
BabbleBeautiful
Yeah, Pro.
Sep 30, 07 2:21 pm  ·
anotherquestion
maybe save illustrator as pdf, rasterize pdf as jpeg, then back to pdf if you must have pdf format.
i've had many a random problem with the illustrator - acrobat pdf transition.
Sep 30, 07 2:39 pm  ·
randomized
Even on 72dpi it looks ugly...
Sep 30, 07 2:45 pm  ·
garpike
Flatten your PDF's into images for on-screen presentation. PDF lines are only loosely to scale when zoomed out.
Sep 30, 07 2:47 pm  ·
BabbleBeautiful
I think I figured it out (for InDesign). In the print dialogue box, select PDF and select options in the left Menu. In the Images: Send Data dropdown menu chose All.
Oct 2, 07 2:11 am  ·
won and done williams
it's how acrobat compresses vector graphics for display. not much you can do about it. my advice is to take your pdf and convert it to a 200-300 dpi jpg in photoshop. use the jpg for on-screen/ppt display. use the pdf to print.
Oct 2, 07 7:59 am  ·
