Currently working on a project with a lot of interior glass while i would prefer butt glazing we are going with mullions. I need a system that has the smallest mullions available. Have tried both Efco and Kawneer and they have 2.25"x4.00" mullions, too thick and heavy. Any suggestions?
this system is SICK! Everything is extruded aluminum and the mullions are the smallest I have seen anyplace. It is Italian and is more expensive but, it is acoustically top notch and quite strong too. Unifor also has a really nice system so maybe check them out?
Glass wall system help
are we talking office front system?? If so then........
http://www.adotta.com/default2.htm
we are talking storefront systems
try ykk
www.ykkap.com
the YES 20 storefront system uses a 2" alum. frame.
thanks J3
checked out YES20 systems but it is a sash system, not a storefront.
hood,
i know you said you didn't want frameless.....but take a look at dorma hardware for fixed glass walls
will do johnson
