EGRESS WINDOWS
yoiyoi
With the min. openings for an egress window being 24" clr vert. opg and 20" clr width and at least 5.7 sqft in area.
For a 3 ft wide double hung window unit (ie 2'6 clear opg-width) to meet these requirements, the clear height of each sash must be approx. 2'3. Now this adds up to about 5' high window unit.
Considering that i would like to maintain common lintel height for openings esp on exterior walls.how do acheive this without having the egress window sill (for a bedroom) just barely 2' aff at the first (ground) floor or am i stuck with one window (egress window) out of sync in terms of sill/header height and size with the other windows in the room?
thanks for your comments
Jul 31, 04 9:44 pm
Ormolu
First, doublecheck your code. I don't know where you are, but in a lot of places there is a code addendum that allows only 5 square feet in area for a window that is on the first floor. In some places you also don't need egress windows in first floor bedrooms if the bedroom is within a certain distance of an exterior door - or in other places if it's within a certain distance of two different exterior doors that are a certain distance from each other.)
If you're going to stick with the 3'-0"wide double-hungs then yes, you're either going to have a fairly low sill height or a high header (the low sill height would be the more typical solution.)
Sometimes clients decide they'd rather go with the casement windows that are designed to look like double-hungs. It isn't a solution that I like, but it's one way to maintain consistency with other windows.
Jul 31, 04 10:33 pm  ·
sam sung
If your egress windows are above the first floor keep in mind that the sill height can not be lower than 36" abv. the finish floor without a guard rail in the window. Often such rails are put in for inspection and then taken out. Recomending guard rails to the client that can be taken out after inspection brings up liability issues. Ormolu's suggestion of casements is probably the best way to go.
Aug 2, 04 3:13 pm  ·
threshold
You might want to look into that guard rail in front of the window comment before implementing it. My experience in residentail is that if the glass opening is closer than 18" to the floor or if the total glass area exceeds a certain value then you need tempered glass, not a guard rail.
Aug 2, 04 3:43 pm  ·
Ormolu
We don't have that guardrail requirement here (but we do need tempered glass below 18" or within 3' horizontally of a door), though it's been a requirement in other locales I've worked in.
It's similar to the variations in egress size and such that I was writing about above in that there's a lot of variation in these egress requirements from place to place.
Do make sure to doublecheck all this stuff with your local code officials. In my state these egress window issues are all addendums to BOCA that you have to get directly from the state, so that you have to read each BOCA clause and then look up that number in the state's addendum and see if there's anything there differing from BOCA....
Aug 2, 04 4:15 pm  ·
BOCA? You are using BOCA and not the new IBC?
Aug 2, 04 5:38 pm  ·
Ormolu
The new IBC has been repeatedly delayed in my state. It won't be in use for at least another year.
When it is finally implemented there will be a similar state book of addendums/deletions/ammendments, as there is in most states currently.
Aug 2, 04 7:53 pm  ·
you don't work near a coastline do you? if you do the new window criteria is extremely restrictive, and many window manufacturers have yet to pick up on the code change...
Aug 2, 04 8:02 pm  ·
