I'm looking for resin coatings for a concrete stair 3 flights tall at a university building in CA. The landings will be in-situ concrete and the treads pre-cast. The coating is intended to offer a higher quality finish, and better tie together the stair and its landings. Does anyone have any suggestions? I searched here, but the results were oriented around resin boards rather than coatings.
try dex-o-tex. if you call customer service they'll help determine which product will work best, and put you in touch with local installers. there are many standadr colors and a very small upcharge for custom colors. we got a bid on a small job for one of their flooring products (not resin, but a more flexible surface coating) at $6/sf including prep work.
Jul 11, 05 10:15 pm ·
Resin stair/landing
Thanks.
-- Alan
Probably in a grey colour, should you care.
you can definitely get leads here
and maybe here
oops the first one is a book store but try going through this list of different manufacturers of various products you will find something
