I'm looking for some suggestions for an exterior polycarbonate/ fiberglass paneling. I've found a decent UV protected corrugated fiberglass panel used by el dorado architects at their Willoughby Barn. I'm looking for products in that genre. Any translucent exterior product suggestions would be much appreciated.
We sampled both Galina and Polygal for this project and found that the Gallina polycarbonate is much more rigid than Polygal, if that matters. Both are available UV coated and fire rated. The Laban is clad in polycarbonate but I don't know the manufacturer.
i used the gallina product..... 16mill i think....bronze... great stuff...light in weight.....if you have it cut to size, watch the ends, you'll slice yourself....
Dec 12, 06 7:59 pm ·
Polycarbonate / Fiberglass Paneling
http:\\www.e-panelite.com
I came across some more in my searches, more would be helpful. Thank you tbwells.
I-CA Enterprises Plastic Paneling:
http://www.i-caenterprises.com/prod_plastic_panels.html
Port Plastics:
http://www.portplastics.com/architect/page12.html
Poly-Gal Polycarbonate + Polypropylene Paneling
http://www.polygal.com/HTMLs/subject2.aspx?C2011=12005&BSP=12004&BSS3=652
Gallina Polycarbonate:
http://www.gallinausa.com/
Poly-gal. great stuff.
Beautiful products. Exterior applications are available.
the polycarb mfr for the laban dance center was rodeca.
they were also the mfr. for this housein germany.
the rodeca systems have a nicer profile than do lexan's.
CPI International
http://archrecord.construction.com/projects/portfolio/archives/0202prada-3.asp
