I'm currently renovating a mobile home in zone 5 (NH) and I'm ready to address the exterior. I've been doing a lot of digging about using ZIP system vs. Plywood and Tyvek (or better yet Dorken) for my exterior sheathing. I'm still confused. The interior has a vapor barrier but it was not caulked at the top and bottom but the seams were taped. Since the drywall is up I can't change that.
That being said, which system should I use? If I use ZIP system in zone 5 I'm concerned about moisture being trapped inside the walls. I'm at a loss here. Cost is not a concern, doing it right is.
The siding I will be using over this is from Modulog, a log cabin type siding made of cedar.
This is a good question for https://www.greenbuildingadvis.... There is an active Q+A section there where homeowners often ask questions similar to yours, even when they're not specifically about "green" building.
The old argument, ZIP system vs Tyvek? Zone 5
Any advice is greatly appreciated.
Don't be cheap and hire an architect to advise you. We are not here to offer you professional services for free.
cost is not a concern? Do liquid applied air water barrier over sheathing. Rigid insulation and then siding in air vented rain screen system.
renovating a mobile home with no cost concerns? sell the trailer and build something permanent where you can design all 6 sides properly.
