Hi All. I am using ICC 2018 on an existing courthouse - adding a couple of courtrooms. Existing courtrooms are skimpy on - or completely lacking - handrails at single/couple steps locations. Are there any exceptions for having a handrail on both sides of a SINGLE step at the Judge Bench and Jury Box, currently?
Thanks, all. Yes, the new work will need to meet code for new construction. I will reach out to the building department for their interpretation.
Jan 14, 20 7:16 pm ·
poop876
What interpretation? It's black and white!
Jan 14, 20 11:10 pm ·
Chad Miller
You'd be surprised how much interpretation is allowed. I've had code officials out right say they aren't going to allow something because they don't like the section of the code that permits it.
Jan 15, 20 9:50 am ·
poop876
Then that plans examiner would look like an ass during the appeal.
Jan 15, 20 10:58 am ·
poop, unless directed by the client, and the reading isn't cost prohibitive, appealing is a fools errand.
Jan 15, 20 11:04 am ·
poop876
I would appeal plans examiners "not liking" something on my own dime!
Jan 15, 20 11:37 am ·
Well, I would as well, if I were develop, design build, but then I'm the money and the client.
Apparently you didn't understand the point of SneakyPete's comment, "Therein lies the difference between ASK your building official and TALK TO your building official." Reaching out to the building department for their interpretation is asking rather than talking.
Many building code officials don't give two shits about ADA. Issues around ADA have little, or nothing to do with life safety, ADA is a Federal Civil Rights issue. Non ADA compliant spaces are handled by DOJ and through civil suits.
Jan 14, 20 11:52 pm ·
poop876
In addition they are not liable for any of it and it's all on the professional.
This isn't a question about ADA. It is a code question.
Jan 15, 20 10:36 am ·
That's a mistake. However, you will need to review existing building codes for any relevant questions, but I suspect that you will find that once construction exceeds a certain dollar amount, you will have criteria to follow with respect to accessibility. Then, it is, an ADA issue.
Jan 15, 20 10:39 am ·
Chad Miller
This isn't necessarily correct. In the 2018 IBC existing building code there are several compliance paths, each have different thresholds for making the building and it's parts ADA compliant.
Jan 15, 20 10:44 am ·
ADA: Civil Rights Legislation. Can get the client sued. While guidelines are provided, there is no guarantee that following them to the letter protects you from lawsuits if the lawyers can prove you did not comply with the law.
IBC: Code. Adopted by the State verbatim or modified. Not Civil Rights Legislation. Often includes ANSI A117.1. This is what code officials are checking against. ANSI A117.1 tracks closely with the ADA guidelines but some variation exists.
Local Codes (mostly in cities): State Code with local amendments. Some cities adopt extra language that tightens the accessibility requirements.
I feel like you (EA) should do a weekly aggregation of the "underrated comments of the day".
Jan 15, 20 1:37 pm ·
Chad - Existing building provisions apply only to those parts of the building you're not otherwise touching with the project. The specific area of alteration always needs to comply with current Code. Example (from the OP): If you are gutting an existing interior space and remodeling into a new courtroom, then everything inside that room must comply with current Code; the EBC applies once you leave the altered room and enter the existing corridor.
Jan 15, 20 2:48 pm ·
OP refers to modifying existing courtrooms, not converting spaces into courtrooms (tho OP also mentions adding courtrooms
I'm guessing they might not have to do anything if they aren't really altering the space, unless the client is requesting upgrades everywhere & then it's a question of what is possible in the space
Jan 15, 20 3:04 pm ·
LittleRed
They are entirely new courtrooms, to be clear.
Jan 15, 20 3:05 pm ·
alrighty, then...ignore the above comment
Jan 15, 20 3:06 pm ·
LittleRed
The "existing courtrooms" I reference in the original post
are elsewhere in the courthouse.
Single Step Handrail Exception? - Courtroom
I think you need elevators in that situation now.
Judge's bench and jury box must both be accessible to persons with disabilities.
Existing buildings have provisions in some cases, no?
Not for areas of new work - OP specified adding courtrooms. All new work must comply.
Yep, I reread it more carefully. Gotta redesign instead of simply replicating the prior design.
talk to your building official
^underrated comment of the day
Not all building officials are qualified to tell you what is required!
can I text my building official instead?
Plenty of building officials care about Chapter 11 of the code and ANSI/ICC A117.1. But you’re right that ADA is not their jurisdiction.
Our state and local building officials review and inspect for compliance with ANSI/ICC A117.1.
Chad, here, it's hit or miss, no laws, but if the code official is an architect, they err on the right side, but they're not required to.
True. It's just that the few areas I've worked the building department did ADA review and inspection.
I've run into that more with For Profit third party groups.
Interesting. May I ask roughly what part of the US you practice in? Myself it's MN and CO.
That's too funny. So do I.
b3ta, is Chad just another one of your personalities and this whole time you've been talking with yourself?
That would be, false, but it does make for an interesting story.
OP refers to modifying existing courtrooms, not converting spaces into courtrooms (tho OP also mentions adding courtrooms )
The "existing courtrooms" I reference in the original post are elsewhere in the courthouse.
"I feel like you (EA) should do a weekly aggregation of the 'underrated comments of the day'."
No way. I won the internet. I'm coasting from here on out.
