I currently have a rather large traveling pavilion project I am collaborating on with a video artist. In a nutshell it is an outdoor pavilion with a 360º projection screen at the interior. The basics space plan and section diagram once considering the projection equipment will yield a +/-50’ radius and likely be in the neighborhood of 40’ tall. It will have an enclosing skin to keep elements out but will not be conditioned. I cannot say for certain what the capacity will be but it will likely be in an Assembly classification and will accommodate accessibility and egress accordingly. I’m attaching below a quick section diagram and a simple 3D array to give a sense of scale. Granted, this is not the proposed design but an array of the section diagram to gain a sense of the whole.
I'm seeking any advice regarding how best to approach the design as it relates to designing a singular object that is transportable and capable of being executed in any jurisdiction in the USA (and beyond), be it a rural field in Iowa or in Times Square, NYC. Clearly I am seeking the most stringent code/zoning/life safety requirements but I am also looking for any experience you, the community, may have had in what portion of any code I might reference as a guide Clearly ICC, ADA, and general Interstate transportation mins/max but what types of permits have YOU had to get for such structures, what experiences have you encountered.
Pointing me in the direction of actual documents would be great (a circus tent permit....assembly class as well as temporary structure....What is that permit?) but I also love a good story, good or bad as they will all have your sage wisdom embedded.
I should also mention that I have in-hand the following documents as a beginning reference figuring these are the most command and likely the most strict:
Traveling Pavilion and multiple municipalities code & zoning regulations
Thank you Archinect community
Federal Size Regulations for Commercial Motor Vehicles
State Transportation Websites
New York City Temporary Place of Assembly Certificate of Operation
Chicago Tent, Stage & Temporary Structure Permit
Los Angeles Temporary Special Events
