thanks. Does one typically follow the nyc building code or do you use ICC? there are a number of different sites that list building codes. Which is official?
Can someone give a straight answer? I don't work for a firm. I work for a manufacturer. Just trying to do some homework for an area I am not familiar with and would like to make sure I am using the correct resource.
I can't speak for NYC, but typically, you start with the highest governing body and move down to the lowest level. So, the state probably has adopted and modified the IBC. Then the city has its own requirements. You have to follow all the applicable codes and standards. As you get to each lower level of government, it typically gets more detailed because the requirements are more locality specific.
New York City has its own building code. It is different from the New York State building code. It also has considerably different requirements regarding how to format and number the permit drawing sheets.
There are lots of permit expeditors that specialize in NYC processing. It is hard to get a medium to large project through without their help.
Off the hop, look up NYC Building Code (2014) chapters 3, 8, 10-12. Obviously, depending on the job, you'll have to review others, but these will give you a sense of the use/occupancy, interior finishes, egress, accessibility, and environment.
Interior Office Space Building Code NYC
What is the best resource for Interior Office Space Building Codes in NYC?
Thank you in advance.
http://bfy.tw/O4v6
https://www1.nyc.gov/site/buildings/codes/nyc-code.page
This is not yahoo answers.
Thank you again.
thank you. that is helpful
Thank you.
NYC building code applies to all projects within city limits. ICC is not applicable.
Project typology is irrelevant.
NYC DOB is the official resource.
Thank you!
Great. Thank you!
In NYC, NYC Building Code supercedes every National Code. Period.
Thank you!
I am NYC Union Carpenter with much experience with Manhattan Office Space reno. If there is a question I can answer feel free.
