white model foam in canada?
bx92
looking for white foam [extruded polystyrene] in eastern canada [montreal]... any suggestions?  tired of painting blue & pink foam models.  thanks!
Oct 3, 18 10:58 am
Use bass wood instead.
Oct 3, 18 11:26 am  ·
bx92
would love to, but can't... long story.
foam's the only option at the moment [it could be polyethylene foam as well, but finish is often too rough]
Oct 3, 18 11:45 am  ·
OneLostArchitect
Home Depot , Lowe’s, Home Hardware, BMR
Oct 3, 18 12:57 pm  ·
Remember to inhale all the toxins you'd otherwise would emit into our atmosphere, thanks!
Oct 3, 18 1:04 pm  ·
bx92
Home Depot , Lowe’s, Home Hardware, BMR... all have only pink or blue.  looking for white.
Oct 3, 18 1:07 pm  ·
racist.
Oct 3, 18 1:18 pm  ·
senjohnblutarsky
Look in the tile section. The probably have some schluter kerdi board.
Oct 3, 18 1:57 pm  ·
bx92
Thanks Sen - I'll give it a try
Oct 3, 18 10:17 pm  ·
alle
Do you need high density foam? Try polyurethane. You can find it online and comes in different colors.
Oct 5, 18 12:46 pm  ·
bx92
Good suggestion... but, I can't use hot wire with polyurethane [at least I don't think so].  Polyethylene foam can be high density and can be hot-wire cut, but I haven't found one with a decent finish
Oct 5, 18 5:00 pm  ·
I think you mean polystyrene
Oct 5, 18 6:16 pm  ·
bx92
i really meant 'polyethylene foam' as it can be hot-wire cut without any significant toxic emissions
Oct 8, 18 9:52 am  ·
So your OP was incorrect?
"looking for white foam [extruded polystyrene] in eastern canada [montreal]..."
Oct 8, 18 11:51 am  ·
bx92
[1] i'm looking for white foam [extruded polystyrene] in eastern canada. [2] however, if there's no white extruded polystyrene foam in eastern canada, white polyethylene foam with fairly smooth finish would be an alternative. [3] the material in question has to be compatible with hot-wire cutting, which excludes polyurethane foam. voila
Oct 8, 18 12:09 pm  ·
OneLostArchitect
check your Walmart arts and craft
Oct 5, 18 8:06 pm  ·
