So, i made this plan based on escher's spiral grid and the golden ratio grid overlapping. left side of the building is double storied and right side is a bamboo hemisphere.
I'm having trouble resolving the grid structure for this. wherever my concentric circle grid overlaps, the columns appear in awkward places. and i'm wondering if there even is a way to keep the plan as close to the original as possible by adding any kind of grid.
A curved wall is much more stable than a couple of columns. Use your design instead of adding something unnecessary. Try bending a piece of cardboard or thick paper and make it stand, now do the same with uncooked spaghetti... simply make physical models (by hand) and study the different structural options, you'll know what to do.
Yes there is a way, you just need to design the structure to suit the concept(s). a simple X by Y grid will always look wonky when the geometry is curved. You need to look at this as a design problem.
For example, increase the size of some columns so that you can delete the most awkward ones and hide them inside of curved walls where possible. Use arches, or trusses, of heavy sheer walls, etc...
May 18, 18 11:52 am ·
sonailaqazi
that makes sense, and do you think a customized grid might work for this? like if instead of the overlapping concentric grid, i follow the geometry of the walls instead
May 19, 18 2:18 am ·
consider other options other than rectilinear grid.
That's for you to figure out. That's why you're in school.
May 19, 18 5:19 pm ·
Yup
May 20, 18 1:51 am ·
Featured Comment
May 20, 18 7:23 am ·
sonailaqazi
do you know where i can find more information on the dimensions and locations of shear walls? or can i just put them in any walls or corner i want?
May 20, 18 11:00 am ·
You don't really need shear walls when dealing with curved walls, they are stable in more than one direction, did you try curving a piece of cardboard already and make it stand? Also look at some Richard Serra sculptures perhaps...
Grand plan gestures like that are gimmicky. People don't experience space like that. Good designers design with light, not plan shapes. It is ok if you are a student, this is why we do school. But I recommend designing with the light.
May 20, 18 1:48 am ·
sonailaqazi
half the structure is a foldable bamboo hemisphere, the double storied part is semi open to the hemisphere, that's where the play on light comes in.
May 20, 18 2:40 am ·
sonailaqazi
but i understand the concern, it's a lot easier to use rectilinear shapes and mold light that way. i'll keep that in mind
May 20, 18 2:41 am ·
I'm not suggesting to use rectilinear shapes because it is easier to mold light. Why is it easier to mold light with rectilinear shapes? You don't want to do what's easy anyways, you want to do what's good.
May 20, 18 10:28 am ·
resolving a spiral grid
Any help or critique would be highly appreciated
1 Featured Comment
All 4 Comments
Scrap the columns, use loadbearing walls, done...
where, how? .-.
Yup
the plan is cool but the section is kinda boring... solution is obviously to add diagonal columns to make the section more interesting
that might help, thank you
