Recycling a damaged shipping container
georgeberz
I am wondering if you cut all 4 sides and the top off of a standard 40' conex shipping container.
Would the floor have any strength as a walking bridge over a creek?
Is there really any strength added to the floor by the 2"x2" square tube running on top above the walls and the 16 guage wavy sides?
George
Oct 12, 17 2:57 pm
1 Featured Comment
All 6 Comments
senjohnblutarsky
Leaving part of the sides would probably give it a bit more load capacity.  You might need to weld in some stabilizing elements to keep the sides from collapsing.
Oct 12, 17 3:15 pm  ·
No, you can't cut out all 4 sides.
Oct 12, 17 3:18 pm  ·
Featured Comment
Why not just build a wood & steel bridge if you're going to cut 83% out of the container?
Oct 12, 17 3:27 pm  ·
Just open the doors on either side and you have yourself a bridge tunnel or tunnel bridge, duh.
Oct 12, 17 4:13 pm  ·
Just to be pedantic about it, you're talking about adaptive reuse of a shipping container, not recycling it ... carry on.
Oct 12, 17 4:20 pm  ·
AdrianFGA
@georgeberz
That's a question you should ask a civil engineer.
If you use only the container floor as a bridge, it may not be strong enough for this purpose. A lot of the structural capacity would have come from the side walls loosely acting as girders.
There are factors to consider like - maximum live load - pedestrians only or occasional light vehicles? a finished surface which will add kN to the dead load; final span; abutment type and anchoring; are parapets required or not; etc.
I suggest you post this question on an engineering forum:
http://www.eng-tips.com/
http://www.efunda.com/forum/fo...
https://www.engineersedge.com/...
Oct 16, 17 1:14 pm  ·
