Wooden beams on top of steel beams?
Aqua123
Hello
So on the first construction detail the person put wooden beams on top of the steel HEB profile. I would put wood beams between the steel beams like the second image, but is there any benefits to put the wooden beam on top of the steel?
My second question is, the insulation of the wall comes a little more than just right between the studs, why is that so?
On the second construction detail the wooden beam is right next to the HEB profile and doesn't have a space of insulation inbetween?
Jul 30, 17 4:40 am
Consulting starts @ $400 an hour.
Paid in advance.
Jul 30, 17 8:15 am  ·
i like the wasp habitat behind the gutter
Jul 30, 17 10:21 am  ·
We do like our wasps in Holland, yes.
Jul 30, 17 3:13 pm  ·
Yep, those ones.
Jul 31, 17 1:34 am  ·
chigurh
WF mud sill
Jul 30, 17 11:00 am  ·
So probably your assignment is due tomorrow, gonna be a late night :)
Jul 30, 17 12:13 pm  ·
Also, you do it like that so you have space for your beermats (bierviltjes)...W
here do you actually study/pay your tuition fee?
Jul 30, 17 2:57 pm  ·
z6jbishop
Are those pictures for ants?
Jul 30, 17 2:50 pm  ·
You know you can click on them, right?
Jul 30, 17 3:01 pm  ·
The detail is interesting.
Steel is used to support all kinds of loads and the wood and steel combo is not a problem but for the fire protection as this is going to be a combustible construction type. It looks like the steel has the intumescent paint.  Sometimes it is common for steel to be used within a wood frame construction to support a sliding door/wall, especially when it is more than 8 feet wide. Otherwise it may be just a look. Also to blow peoples minds back in the day used to build brick arches between steel beams.
about the insulation extending beyond the studs, this is probably not the bat insulation but some kind of rigid insulation and or sheathing to hold the bat insulation in place.
Over and OUT
Peter N
Aug 5, 17 7:28 am  ·
Too late, I think he already failed his class.
Aug 5, 17 7:52 am  ·
"The detail is interesting."
Really? Those details are interesting only as far as they demonstrate the complete incompetence of whoever drafted them.
Aug 5, 17 9:12 am  ·
I think the OP "drafted" it because it relates to a previous post of his/hers.
Aug 5, 17 12:07 pm  ·
