an x architect in New York city generate drawings for a facade job (cornice removal for cladding installation) that i'm currently working on. so he circles all the areas for demolition BUT he miss 2 areas. as a general contractor base my estimates on all locations circle by him. Now he added a general note saying the fallowing: 1. remove and or cut-back any protruding decorative masonry cornice,window head,column capital,etc in conflict with new metal panel system. He doesn't want to recognize the extra work!. what should i do?
If it was not on the original drawing that you bid on you may not have a contractual obligation to preform the work so long as it wasn't obviously an error and the plans didn't require you to field verify. If it was obvious that the drawing had an error, and that the demo of those 2 things was necessary to install the panels, or if there are notes limiting the role of the designer and expanding the role of the contractor to field verify certain things, or leaving the scope of work flexable to provide room for additional demo as needed to preform installation, then you are probably bound to do the work. Again, it all depends on the contracts and drawings...
Hard to say without more detail, but generally, if you received the info during the bid period as part of an addendum or a pre-bid conference (even if you ignored or missed it), it's probably on your plate. If the architect added the information to the CDs after bidding closed, then it's probably a change order. I would make the owner and the architect aware of this, if so. Maybe the owner is already aware of it, who knows.
Jan 5, 17 11:32 am ·
what do you guys think about this!
^what's the scope of work say on the drawings?
You probably should have asked the question during the bidding process since you recognized that there were two areas not circled.
lawyer up
I usually see pre-bid meetings where this kind of thing is discussed. Did you visit the site and verify conditions and scope?
What is an x architect anyways? A former architect? An unmentionable architect?
