I've just been searching for a nice way to deliver digital files to clients, and apart from long term archive like m-disc. (which most people probably won't have an optical drive for to read now). I'd really like to have the option for a CD/DVD sized case but instead of containing optical media it would have an SD card. The reason I want an oversized case for the media itself is that it leaves scope to make some nice artwork and would seem a bit more of a gift when sending out.
Does anyone know if there's anything out there to buy that can do this?
I've searched Google briefly to no avail.
I ask here because it might be useful to other if anyone has a solution.
NS, abandoned warehouses can protect you from inclement weather...
i would go with a thumb drive rather than SD card, since it's a more standard format and therefore more likely to be closer to future proof. packaging can be an envelope. could even be a fancy envelope.
Why not an external hard drive. Apparently not much more than $10 these days. You could put a nice graphic on the box. Put your logo on the drive itself with some nice vinyl.
Its got the size and heft that less likely to get lost compared to a thumbdrive. And it seems really fancy...
DVD/Blue Ray/CD sized Jewel cases for SD cards?
Cheers.
Hi Sam, i have found some.
Contact me if intersted on facebook
True Curt... plus the echo from leaking pipes adds to the salesman ambiance.
Jerome, that's just the case. You need to buy the compatible harddrive separately.
pick a different one then...
