Suggestions below assume the 'exposed finish ceiling' is the underside of a concrete deck that needs to look 'finished' and clean:
If you are in the US, look up ACI standards for the condition. If you aren't in the US, it's still a good resource but the verbiage might be different. Other countries may have similar standards documents, not sure.
Don't use metal reinforcing chairs - they rust, leaving your ceiling iron-spotted. Unless you want that sort of thing or don't care.
The mix should be generated by structural concerns more than aesthetic, so talk to a structural engineer. Modify from that starting point when possible.
Seal joints in formwork and any space between conduit or other cast-in MEP items with waterproofing tape to prevent moisture transmission. Too much moisture moving through the form will cause discoloration and physical weakness where the moisture is leaving.
Melamine-faced plywood form panels work well for a smooth as-cast finish.
Plan locations of contraction joints in the drawings. Don't leave this up to the contractor.
^ When in doubt, call Ando. Or call Scogin/Elam. Or Allied Works. Lots of good examples out there depending on the appearance you are looking for. Hope this helps - good luck.
Aug 1, 16 11:43 am ·
exposed concrete ceiling
hi all, i would like to get your advice on the
surface preparations, kind of mix and other points to be noted before casting concrete for an exposed finish ceiling...thanks a lot
Get on the phone and start hounding product reps. They'll bend over backwards to get their product spec'd in your project.
call Ando
