Side yard setback is the distance between the house and the property line, so isn't that's only about half the distance between the houses. Just a thought.
Jul 8, 16 3:38 pm ·
Fire separation distance?
The correct term depends on what you are saying are really referring to. In the building code, there are terms used to refer to the separation distance between buildings (including houses by the way).
Jul 8, 16 5:11 pm ·
Technical Term
What is the technical term describe the distance between two houses?
distance is measured in Furlongs
if its zoning, its side yard setback
if its construction, its fire separation distance
if its zero lot line, its an alley
if your a voyeur, its unmanned aerial drone flight path
Infill.
structures separation
