What do you call an indoor balcony that is on the second floor? You know, where part of the second floor is cut away so you can look down and see the first floor?
I think an atrium is just a large open space in a house, and a balustrade is a railing. So those aren't quite what I'm talking about. What I'm talking about is when the second floor is open to the first floor, so you can look down from the second floor into the first floor - as if you're on a balcony, but you're indoors.
Thanks you guys! I've been looking for a while. I'll try searching with the keyterms "Interior Balcony" and "Overlook". I already tried using "Loft", but unfortunately, that didn't seem to be quite what I was looking for.
If you're just looking for examples you could also try "home mezzanine". What you're describing isn't really a mezzanine, but you'll find some interesting examples which are similar enough.
Donna, mezzanine implies it's between the first and second floors, Correct? Both of those appear equal to the second floor.
Nov 5, 14 10:11 pm ·
caramelhighrise
Just call the second level "3". It worked for the 13th floor, didn't it? Also my freshman year dorm had an off-limits basement, "ground floor", "Mezzanine", THEN 1st, 2nd, so on... At this point I'm pretty sure architects are anarchists.
1 a low-ceilinged story between two main stories of a building; especially : an intermediate story that projects in the form of a balcony 2 a : the lowest balcony in a theater b : the first few rows of such a balcony
French, from Italian mezzanino, from mezzano middle, from Latin medianus middle, median First Known Use: 1711
It's a balcony. Even if that is not the correct term or description when you mention a balcony to people in relation to residential they think of something like the pics.
Is this not a Gallery? The word is pretentious, but seems right if we are talking about a Great Room, which is the clearly the location for this particular element.
Both terms are defined in Chapter 1 of the Fall 2014 Parade of Homes brochure.
You could call it a gallery - but gallery is a word with many meanings, most more common than the meaning of a kind of balcony. For the OP trying to look up examples, it will be hard to find what he's looking for if he calls it a gallery.
I would call it a loft before I'd call it a gallery, but I appreciate how you're citing a source, Janosh!
The building code has a specific definition for mezzanine as a partial floor with size limits based on egress. That's how I'm thinking of it. Granted, that relates more to commercial than residential, I think.
Those are usually called lofts when real estate agents and home owners talk about them (assuming you are looking from a homeowner perspective?) It is very popular in vacation condo type housing here and that is what they call it. Edit after I looked at the pics again. Loft usually implies a study or a sleeping area, not a circulation space.
How about overlook? Or as it is often labeled on plans "open to below"?
I think the first example appears to be more of a study type loft, yet I agree the second one does appear to be more of a circulation area. Perhaps the second one is more of an open corridor as Donna suggested. The only thing that distinguishes it from an upstairs hallway is that it's open.
'corridor' is different than 'hall' in that it is often required to be rated and all that. perhaps it's more of a hall than a corridor? i suppose it is an egress component for the people on the second floor though. if the second floor is a mezzanine, then it's considered a portion of the story below and might not scope the corridor requirements?
MEZZANINE. An intermediate level or levels between the floor and ceiling of any story and in accordance with section 505.
you can have a mezzanine in a single story building. i do it all the time.
there's no such thing as 'too fancy.' that's like too much money in the bank, or too in-depth code review for a question that isn't asking about a code review.
CD.Arch, ceilings are not considered levels and neither are roofs, unless occupied. I know there is a paragraph somewhere in my code that permits the stacking of mezzanines essentially describing the max area in case you want a wedding-cake like grouping of mezzanines on mezzanines.
I've personally use the term open 2nd-level landing if immediately adjacent to the staircase.
cd.arch, my definition of mezzanine was literally copy/pasted from the code book. had i typed it, i would have excluded the capital letters.
there are occasions when the difference between mezzanine and floor are important, such as height and area restrictions. in those cases, one might hope for a more clear distinction so the plans examiner doesn't cause your project to be scrapped. this, however, is what the code provides.
STORY. That portion of a building included between the upper surface of a floor and the upper surface of the floor or roof next above (also see "Basement," "Building height, " "Grade plane" and'' mezzanine"). It is measured as the vertical distance from top to top of two successive tiers of beams or finished floor surfaces and, for the topmost story from the top of the floor finish to the top of the ceiling joists or where there is not a ceiling, to the top of the roof rafters.
MEZZANINE, LOFT. An intermediate level or levels between the floor and ceiling of any story with an aggregate floor area of not more than one-third of the area of the room or space in which the level or levels are located.
505.2 Mezzanines. A mezzanine or mezzanines in compliance with Section 505.2.shall be considered a portion of the story below. Such mezzanines shall not contribute to either the building area or number of stories as regulated by Section 503.1. The area of the mezzanine shall be included in determining the fire area. The clear height above and below the mezzanine floor construction shall be not less than 7 feet (2134 mm).
505.2.1 Area limitation. The aggregate area of a mezzanine or mezzanines within a room shall be not greater than one-third of the floor area of that room or space in which they are located. The enclosed portion of a room shall not be included in a determination of the floor area of the room in which the mezzanine is located. In determining the allowable mezzanine area, the area of the mezzanine shall not be included in the floor area of the room.
Where a room contains both a mezzanine and an equipment platform, the aggregate area of the two raised floor levels shall be not greater than two-thirds of the floor area of that room or space in which they are located.
we have one similiar to the pic and we are not fancy so we call it the "catwalk" lol. Our ☆upper interior 2nd overlanding baloftcomezzany☆ which I will now name it is well to wall over the living room and stairs hidden in front foyer
Word for indoor balcony?
Examples :
Atrium?
loft
Interior balcony.
Sadly no fancy word for such a thing. 'Interior balcony' is probably the best term for this. You could also call it an 'Overlook'
Unless you hire some musicians to perform there. Then you can call it a minstrels' gallery!
That carpet in the second picture is awful.
Lol...architects.
Thanks so much for all the help! I appreciate it.
Loft
lol. architects... that guy is funny^
That's totally a mezzanine.
MEZZANINE
Mob rules
does anybody remember laughter?
It's not a balcony.
505.
I think you're getting a little too fancy with it. I would call both instances of what you have pictured "landings."
That's an endogenous entresol.
Makes me wonder what all of you were doing in architecture school. Probably busy trying to get laid.
Mezzanine!
Landing. Also the 70s called, they want their stair carpet back.
Depends on what you do there.
Generic? "Gallery"
"Loft" is an inelegant word. Loft is where you store hay.
Mezzanine, gallery if it is connecting other rooms, loft if the whole space is not sufficiently tall enough to stand in, or just a balcony
Peter N
IRC 2012
Who know's these photos don't tell the whole "story".
Landing at the 2nd floor (or upper whatever level) or the second floor simply. Neither photos are balconies.
The images you shared of indoor balcony are so awesome. Its not looking too much fancy or over creative. Its simple and great. Good work.
^ really?
^ Mezzanine.. but what would you call this type of indoor balconies?
It's a vide, which is to say, a void. French "leegte." But I would use "wide landing" or "balcony" for most audiences.
Forgive me for being obtuse, but that looks like a mezzanine to me.
IBC has some pretty specific definitions for a mezzanine. You might call it one, but in the eyes of the code, it probably isn't.
LOL @ how this thread keeps returning!
I would call this a vide. It's a French word for empty space, and in Europe the word is used for a partial second floor as shown in your pics.
Its a fucking mezzanine, thread closed.
505.2 Mezzanines.
loggia (n.) "roofed galley used as an open-air room," properly at a height of one or more stories, 1742, from Italian loggia, from French loge
A loggia is usually a passageway open to the outside of a building on one side often through a series of arches along the passageway.
Loggia should have a roof an open on one side
(https://tranio.com/spain/)
New attempt from memories of arch school and the modernist guard of teachers: entresol
Yes, an entresol or mezzanine. It's the same thing, one is from French the other Italian origin.
