inserting into posts
can someone explain to me or point me to a previous post (because searching hasn't proven fruitful) that tells one how to insert hyper links and images into posts? thanks.
Nov 5, 04 11:00 am
el jeffe
look at the grey text instructions directly below the "Post a response..." line.
Nov 5, 04 11:32 am  ·
instructions are below the comment box.
French
look at the bottom of this page, which explains you the codes to insert images and links:
Required code to post a link - link
Required code to post an image -
ether
can something be posted from my c: drive?
here
Nov 5, 04 12:05 pm  ·
ether
well that didn't work..
Nov 5, 04 12:08 pm  ·
Per Corell
Hi
No your link or picture need to be on the web ,there be a bit fiddeling if you don\t copy and paste right , I use to find the link first copy and past that, then copy and paste the instructive text at the bottom and replace the example link with my link
Say you copy and paste this link onto this page;
http://www.spacedaily.com/images/mars-mera-thirdperson-bg.jpg
With this you just type "" after the link
Se the instruction as "image start" ---image link----"image end".
Nov 6, 04 6:13 am  ·
Oct 17, 07 6:46 pm  ·
Oct 17, 07 6:47 pm  ·
babs
namhenderson:
here's what you type -
[ img ]http://www.spacedaily.com/images/mars-mera-thirdperson-bg.jpg width=418[ /img ] (*)
to get this:
(*) note - leave out the four blank spaces in the bracketed commands at the beginning and end of the expression -- I had to put them in here so the picture would not appear twice.
Oct 17, 07 6:59 pm  ·
