The only real way to do it, I think, and this is one of the shittiest things about illustrator, is to take a known measurement, say a 6" wall, and scale the drawing so that measurement is 1/2". You'll have to select the whole drawing and use the scale tool. Get the length of the segment, and come up with the percentage you need to get that length to equal to 1/2" and scale the whole drawing by that percentage. It's annoying.
If anyone else has a better way, I'd love to know it.
I would always draw a box that represented my sheet size at the proper scale in AutoCAD (sheet size x inverse of scale you want (1/8"=1' is 8)). Then when I import it to Illustrator size the box to the proper sheet size. This is my lazy way that avoids math are measuring in Illustrator OR you could scale your drawing in AutoCAD and when you import into Illustrator, uncheck the option that is "fit to sheet" or something like that.
the cadtools plug-in adds scale, trim, extend, dimensioning, etc. functionality to illustrator. you can edit drawings exported at a known scale or create drawings from scratch.
we use it way more than we should...
it's made by hotdoor.com
Oct 26, 04 1:15 pm ·
question: how do I scale drawing imported into Illustrator from CAD?
Say i want to scale the drawing I imported into Illustrator from CAD at 1/8" . How can i do this efficiently?
thanks a bunch
with scale tool:)
thanks for the responses!
