rhino huge file ? !
hey - dumb question for rhino users out there , i'm a rookie so please forgive ...
modeling out what turned out to be a very bigh file made of many repeated small parts ... and the program keeps saying no more memory available , and crashing..
the file size is something like 400,000kb .
is there a way to model out a system that has hundres of similar elements? ( actually 4,200 similar elements to be precise ) ...
thanks and hoping someone can tip me in the right direction ..
Oct 4, 09 7:50 pm
ff33º
you can try a c&p to another file to help clean it up..but mainly..you need to figure out a way to get a lower poly count. Also I think mesh modeling is lighter computationally...sorry can't be of more help.
Oct 4, 09 8:23 pm  ·
Ian & Jonas
Wouldn't block instances help immensely?
I am not certain, but that might significantly reduce your file size.
Oct 4, 09 10:49 pm  ·
not_here
yeah... use blocks when modeling and start pruning, it will help a ton.
Oct 5, 09 8:23 am  ·
c
i've wound up do a placeholder version of my design with simplified geometry -it's not the real thing , but it allows me to use it to run the daylighting analysis i was hoping to run - - this basicaly means i postponed the problem ..
is max considered any better for huge files made of many components? i dread max ...
Oct 5, 09 11:09 am  ·
