autoCAD batch plot
marik
Does anyone know how to plot a batch of drawings in AutoCAD 2009? For instance, is it possible to plot an entire construction set from the .dwg format all at once? I'm really sick of opening a file and selecting "plot previous" over and over again...
Jul 21, 08 3:12 pm
Antisthenes
sometimes it works sometimes it doesn't.
save your plot profile
and when you open batch plot add all the files and tabs you want printed
and then select them all
then right click on the one that has that saved profile, select it and it applies that to the rest and save your batch if you want and plot..
Jul 21, 08 3:27 pm  ·
marik
that sounds great..but where is this "batch plot" option located? Also, i got a tip that using e-transmit and adjusting the settings may also work for plotting an entire set...
Jul 21, 08 3:34 pm  ·
Antisthenes
a separate icon on the start menu? or file > publish
Jul 21, 08 4:32 pm  ·
gonad
make a desired page layout, then use publish.
Jul 21, 08 7:19 pm  ·
marik
k. publish works fairly well...except i have to sit there and select "yes" fo every single print. Still, it is a huge improvement. thanks.
Jul 23, 08 11:43 am  ·
marik
selecting "yes" because i was printing .pdf's and the computer was asking me to confirm the file name and location.
Jul 23, 08 11:45 am  ·
Antisthenes
what PDF printer? some have options to automate that
Jul 23, 08 12:11 pm  ·
marik
i was using one called "adobe pdf writer" but that's a good point...i'll try the other one we have.."distiller"
Jul 23, 08 7:34 pm  ·
toasteroven
sheetset
Jul 24, 08 12:56 pm  ·
