heat resistant coating for stainless steel and/or aluminium
yiupong.chan
Is there any recommended coating for stainless steel / aluminium so that it wont over baked under the sun ?
thanks !!
May 13, 13 12:41 am
accesskb
use wood
May 13, 13 1:24 am  ·
rabbits
paint it white.
May 13, 13 2:59 am  ·
Warp it in hand-tooled leather.
May 13, 13 8:38 am  ·
ncecchi
Um... Inox or Aluminum is going to have to get pretty hot to become "over baked" in the sun, unless you are referring to it getting too hot to touch or lean against.
The whole idea behind using (especially Stainless) as cladding is that it has a natural passivation layer so there is no coating required other than what forms due to the environment.
I guess I don't really understand your question.
May 13, 13 12:10 pm  ·
gruen
It will get as hot as its environment. Might get hotter based on its color (white vs black).
What is your goal? There is no coating that will expel heat, but a white paint will absorb less solar radiation.
May 13, 13 12:35 pm  ·
