ArchiCad Tutorials / Help...
aaron mwj
Hi...
I am a completely new to ArchiCad, I am looking to produce a wireframe landscape....think cover of Joy Division, Unknown Pleasures or the sort of thing you get when you see plotter images of the ocean floor.
I have tried 'googling'.....I went to a demonstration of ArchiCad and it seemed like the tool to use.....so....
any advice would be really appreciated!!
AMWJ
Mar 13, 08 1:15 pm
evilplatypus
Advice = Autodesk Autocad
Mar 13, 08 3:15 pm  ·
baldo
mesh tool, 3d wireframe
Mar 13, 08 3:17 pm  ·
crowbert
One thing that ArchiCAD isn't too hot on is topo. I really like the program, but there's things I know they didn't spend a lot of time on.
That said, make a mesh with a lot of points, then go into the 3D view, and option-click to bring up the little button-box to the side of the cursor - there should be a little angle type symbol with a Z on it - click on it and and stretch away!
Mar 13, 08 3:47 pm  ·
Antisthenes
advise - Rhinoceros
the terrain plug-in it works for autocad
Mar 13, 08 3:50 pm  ·
evilplatypus
you can always do topo in max and export it to acad
Mar 13, 08 3:55 pm  ·
Orphan
once the Mesh is done and you are looking at it in the 3D window save as a .2dl (2d drawing) it will save the view at the same angle that you are looking at and it will convert the mesh into lines it will make its own separate file, just open it up and clean up accordingly.
_late
Mar 13, 08 4:55 pm  ·
crowbert
Sometime when all you have is a hammer, everything starts to look like a nail.
I wouldn't recommend ArchiCAD for even moderately complex topography, but if you don't have access to the other programs, then you'll just have to muddle through.
Mar 13, 08 4:57 pm  ·
aaron mwj
Thanks everybody....really appreciate your feedback!
Mar 14, 08 7:20 am  ·
