For a system that uses pantographs, the wire is called a cantenary. For a system that uses trolleys, the wire is called a trolley wire. (Cantenary wires are held at a constant tension, and are capable of powering trains at much higher speeds than trolley wires, even if the voltage is the same.)
Thank you. That's catenary, I think (also describing the curve made by a chain suspended from two points, similar to but different from an ellipse).
(Dad was a mechanical engineer and railfan, as you may be also ?)
A graphic pantograph is a device of levers and pivots which enables the reproduction of an image on an adjacent surface, either at 1:1 or at a different scale.
Riding the SLUT
I just felt like posting this.
Technically, it can't be called a trolley because it uses a pantograph instead of a trolley pole for its electrical pickup.
Pantograph:
Trolley pole:
LIG
what are you, a fucking park ranger?
And what is the wire called that is contacted by the pantograph or the trolley pole ? And what is the drawing device, also called a pantograph ?
I have no idea about the drawing device...
DEEZ
ride the snake... to the lake...
i'd ride it
