Rhino modeling
morfo
Anyone know how I could cut a section/elevation in Rhino? Something similar to the clip planes in autocad?? Thanks.
Jun 21, 07 1:18 pm
FOG Lite
If you are using Rhino 4 you can just type in "clipping plane" and you'll be able to see it in a viewport. However, you'll have to be more specific with what your desired end result will be. i.e. a rendering, acad section, etc. If you just want to look at a section on screen then you're good. Rhino 4 has much improved printing but I haven't played with it enough to see how well it works.
Jun 21, 07 1:26 pm  ·
morfo
oh any trick with Rhino 3?? I haven't upgraded to version 4 yet
Jun 21, 07 2:18 pm  ·
archasm
you can just type "section"
and it will ask you where you want the section to start and end and voila!
you'll have yourself a section.
Jun 21, 07 2:20 pm  ·
BrentJWatanabe
Rhino 4.0 has the "ArchCut" Tool available from Rhinolabs.
I would use this tool.
Jun 21, 07 2:40 pm  ·
BrentJWatanabe
Sorry...didn't see you didn't have 4.0 yet.
Could always export to ADT and cut a section there.
Jun 21, 07 2:41 pm  ·
morfo
I got the section... just missing the elevation behind. I export to autocad but then the massing comes out to be these meshes and it becomes hard to c... anything else that would be able to help?? maybe a setting during export so it would come out as simple mass instead of the mesh polygon?
Jun 21, 07 2:47 pm  ·
DEVicox
last resort. split model and shoot a make2d.
bad option, but it will work.
Jun 21, 07 4:29 pm  ·
BlueSteel
why is that a bad option dev?
i do that all the time. it takes a few steps, but it works very well.
Jun 24, 07 3:58 pm  ·
grid
i do the split - make 2d as well. yay.
Jun 25, 07 1:15 am  ·
Antisthenes
i do that as well make2d combined with section.
Jun 25, 07 2:53 am  ·
garpike
first resort. split model and shoot a make2d.
good option, and it will work.
Jun 25, 07 3:13 am  ·
morfo
thanks. it works.. well!
Jun 26, 07 9:15 pm  ·
FOG Lite
I do that all the time too.
I also draw my section plane, then do an intersect if I want to keep my surfaces whole. When looking for those lines in the way back I'll dup edges and then project them onto my section surface. Once done and my sections been exported to a dwg I'll select all curves, delete and be on my way.
of course there's also "ctrl+z"
Jun 27, 07 8:47 am  ·
_ks
you should just script everything. it's quicker...then just assign then script as a macro to a button.
Jun 27, 07 10:25 am  ·
Jonas77
rhino script is very very powerful
Jun 27, 07 1:58 pm  ·
DEVicox
first option should be using clipping planes for complex models. when working with models that have very complex skins, the split will fail almost everytime. or crash your machine (even a powerful workstation).
for simple stuff splitting should be fine. i agree.
Jun 29, 07 3:07 pm  ·
