Help - exterior wall tile detail
Rottnme
Can anyone help me find some information on how to properly detail exterior wall tile on a curved wall?
Our typicall is to use a 1/2" Burarock backer on straight walls with tile over the top. The curved entry walls are posing the challenge. The curve has a 4' radius, the project is in Wisconsin and will be subject to relatively harsh winter conditions. Any help would be great. Thanks.
Apr 27, 07 9:38 am
liberty bell
What is the curved wall made of? I'm thinking you're asking for failure if it's stud construction...
Apr 27, 07 10:55 am  ·
Rottnme
Sorry I should have been more clear on that. They are stud walls. Right now we are looking at using 1 layer of 1/4" plwd sheathing, daimond mesh and cementicious coating as a rigid base layer (somewhat equivalent to the Durarock), finished off with tile using epoxy adhesive and grout. The walls will be partially protected by an entry canopy, but I'm not sure that that is enough to prevent problems and I find it hard to believe that this hasn't been done before hence my looking for help.
Apr 27, 07 11:23 am  ·
