Help with Modeling Material
ichweiB
I am building a model and need some help locating a material. I want to represent the skin as a mesh-similar to Steven Holl's Sarphatistraat Offices. I was wondering if anyone knew of a perforated material preferably a metal that is rigid and that I could possibly paint. Essentially, I am wanting something like tin that has thousands of small holes in it.
Thanks
Mar 19, 07 12:46 am
FOG Lite
Depending on the scale of said model, I would use sculptor mesh. Often it's called "wireform" or some such.
Mar 19, 07 1:07 am  ·
Or you could actually get real perforated metal at the smallest scale you can. I've done this before for 1/2" detail models and it worked beautifully. Not sure where you're at, but I got that stuff at a shop in Pomona that sold it for about $10/sq. ft. For the whole-building model, I just found the densest mesh I could and it turned out well. If you're in the LA area, I recommend SCI_Arc's supply shop for your metal needs.
Oh, and yes, I spray painted both of those materials, and they took it fine.
Mar 19, 07 1:11 am  ·
FOG Lite
If you're in LA SCI-Arc supply shop will have the best selection of meshes hands down.
Mar 19, 07 9:31 am  ·
for a cheap alternative, depending on the scale... both readily available at any hardware store...
window screen material...
or...
spray paint some drywall sanding screens with a metallic paint...
Mar 19, 07 9:44 am  ·
what about brc
Mar 19, 07 1:15 pm  ·
mdler
look for photo-etched steel for model railroads
Mar 19, 07 1:20 pm  ·
xtbl
i agree with rationalist and recommend not using a mesh and actually using a smaller scale perforated metal sheet.
the store in walnut is called carpe diem.
and the sci-arc supply store should have it too.
Mar 19, 07 1:24 pm  ·
cmu268
wire screen, like in windows
Mar 19, 07 11:49 pm  ·
binary
aluminum bug screen
perforated brass..... evergreen models/micro form models/plastruct
or just go to the dollar store and buy some cheap speghetti strainers and cut out what you need........
brass
Mar 20, 07 12:51 am  ·
bucku
does anyone know a substitute for resin that is easier to work with perhaps?
Mar 20, 07 2:59 pm  ·
pmossimo
glycerin
Mar 20, 07 8:57 pm  ·
binary
mix resin with the hardener and then mix in bondo with the hardener.... you can figure the consistancy by adding either/or.... works great..... easier to sand and you can get a good flow......
but fiberglass resin is getting expensive... it's a petroleum product.... oil...go figure...
b
Somnambulist
check ACE hardware for a drywall hole patch. they are metal, fairly rigid and about 8"x8" (not the biggest unfortunately), and have....hundreds of tiny holes in them. i used to use them all they time for my models and they work great........but only if you're NOT in the LA area.
Mar 21, 07 2:35 am  ·
