I was basing my guess off of this detail, which has hinge in the name and the component is a hinge. The webpage i took the pic from described it as a column joint, but that is specifying the connection and not the details of the connection. Although this type of connection is rarely used isn't it a standard detail, i've seen it before, but only ever ambiguously described as a pinned connection.
Oct 5, 06 3:43 pm ·
structural connections 402 - pinned joint support
what do you call this, a hinged column anchor, hinged anchor?
[imghttp://moment.mit.edu/imageLibrary/images/large_images/Fig24.JPG[/img]
my guess would be like a 4 flanged setting plate for a pinned conection.
Do they use special bolts and nutz for connections like this? Any engineers out there?
