how thick?.... i have used brass/aluminum in some models and usually you can cut it on the band saw... i would recommend buying a separtate blade... fine tooth should be good...also get a meium thickness blade.... too thin and it'll snap too easily and too thick, you will only be able to really do straight cuts...... you can also rough cut on the band saw and then finish up on a sander....... if there is no shop, use a utility knife and do a bunch of scores.... light scores and alot of them...it'll help keep control...then you can bend/snap with a striaght edge on the top and the bottom......
i have a few models on my site that i have used various materials...www.237am.com.....
good luck
Sep 23, 06 6:18 pm ·
How do I shape my material?
I'm working with thin gauge aluminum and copper and was wondering what you would recommend to cut and shape it.
thanks.
Do you have a wood or metal shop on your campus? They will most likey have the tools you are looking for.
good luck
