Importing into 3dstudio from autocad (exporting a 3ds from autocad). I have a lot of individual panes of glass which need to individual objects once imported into 3dstudio. They are all on one layer in autocad, and show up as one object in 3dstudio. Is there anyway to get them into 3dstudio without them being grouped like this, but instead individual pieces.
I mean besides putting each object on its own layer... or is there a slick way to put objects on their own layer in autocad, without doing it manually?
Yeah, what mau said might work but you could also try the following if you only want the glass as individual objects and not every layer in the scene:
Importing the glass layer into 3ds as a separate file, but select the "individual objects" option (or whatever its called... I dont have 3dsmax open) in the import screen. They should import into the scene at the original coordinates.
Also, you can just select the glass group and then modify-> edit by vertex subobject -> and select each piece of glass and press the "detach" button... it'll ask you to name the new object each time.
I apologize if the directions are a little innaccurate, but I don't have 3dsmax in front of me.
autocad/ 3dstudio import question
Fellas and Ladies,
Thanks. Back rubs are on me next time.
you could link the file to 3dS and choose by color or by object
Just uncheck the "Combine objects by layer" and 3ds will import your glass layer into individual pieces.
Thanks guys. Got it to work.
Cheers.
