I just recently began buying Xactos again (there wasn't a big need after graduation) and when I took out the blades they were a nasty mess. This happened on both the Number 11 blades (they come wrapped in plastic inside the box so their oil doesn't spread), and the ultility blades (just as greasy) What gives? Who do I complain to? THis really messes up model materials, Chipboard doesn't look so good with an oil slick on it.
same goes for piano wire (used for sodering models)...during undergrad one had to be sure to wipe the wire clean or risk getting grease all over the place...
hand tools should be stored in a drawer lined with a piece of scrap carpet moistened with light machine oil. the carpet prevents tools from getting scratched and nicked, and the oil prevents rusting. replace the carpet if it becomes caked with sawdust or dirt.
What's with the Oil Spill on the Xacto blades...?
Oil prevents rusting. Wipe them off. Same reason you store a wok (a good wok isn't stainless steel) with cooking oil on it.
a newly honed engine cylinder gets sprayed with wd-40
when you buy angle iron (steel) it comes oiled. Same reason I keep an even coat of oil on my chest at all times
