researching in the field of structure and techni of NOX's water pavilion, which used cad cam tech., is there any company doing such steel/aluminium fabrication, and any good website to describe how the construction works, last, any similar projects around the world, thank you.
cad cam technologies
I thought the water pavilion's structure was plywood.
not steel, but definitely CNC, another nox project, the d-tower: http://www.arcspace.com/architects/nox/d_tower/
I work at such a company, I can help you if you have specific questions.
For a listing of other companies check out Thomas Register
and a video of a three axis vertical mill, the most common type.
besides NOX, Bill Massie and Ron Arad have also worked in this area.
just watch some hot rod and chopper shows man.
thank you to all.
i am currently looking for more reading
on the field first, any good books or journals?
appreciate all your help
You might want to look at "Digital Design and Manufacturing: CAD/CAM Applications in Architecture and Design" by Dan Schoedek et al.
