Wood or cardboard for a presentation model
Pete
I need to make a 1:100 scaled presentation model for the final. Which material is favorable for this scale, wood or cardboard?
May 13, 05 3:07 pm
MACattack
Use card board. It's easier to work with not unless you have a CNC machine that can mill the structure/(structures) out of solid wood. The solid piece of wood will be expensive though.
MACattack
May 13, 05 5:38 pm  ·
Jrocc
Depends on the size of the project. I would say wood myself maybee a plastic even if you want to get a bit more spendy. CNC please learn how to use a wood shop, nothin worse than an architect thats scared of a saw.
May 13, 05 5:56 pm  ·
momentum
at 1:100, wont cardboard be large for some items? i'm basing this on 100'=1"? otherwise for 1"=10' it would be great if your into cardboard.
May 13, 05 6:19 pm  ·
trace™
I'd opt for museum board, probably. Anything you get, just get the 1/32" thickness. You should be able to get it in wood, chipboard, or museum board.
In the end, you just want it to look good. MB and CB would be the easiest to cut, and the cheapest.
May 13, 05 8:06 pm  ·
