Extruding profile along 3D-polyline path
domestic
I've found this ACAD extension called tube.lsp at http://www.schorsch.com/download/tube/
which will allow me to extrude profiles along 3d-polyline paths for purposes of making a spiral stair.
I'm trying to install the extension and inorder to do it i'm suppose to copy it into the location on my systems hard disk that autocad searches from its "acadprefix" system variable, but where is it? where is the directory that acad searchs for its prefixes? I've looked and the closest thing is under the support directory,except copying it there doesn't work.
Thanks
ACAD should've had this since day 1.
Apr 9, 05 6:15 pm
Saturn
Hey domestic. Drop that file in the directory of autocad in the support folder. For instance C:/ProgramFiles/ArchitecturalDesktop3.3/Support.
Then open autocad and type "appload". This will bring up a box that will ask you to identify the .lsp file. Pick tube.lsp and hit "load". This should do the trick.
Apr 9, 05 7:10 pm  ·
domestic
Saturn
THANKS!!!!! GRRRRRRRRREAT
Apr 9, 05 9:21 pm  ·
