ACAD Autosave file question
domestic
an error has occured thus crashing acad so i'm using the autosave file to get back to work. I've changed the extension of the file to dwg from $ve and tried to open it but when i do this message pops up,
'Cannot find the specified drawing file Please Verify that the file exists'
What step(s) am i missing?
From what I understand changing the extension is suppose to do it except it doesn't so how do i make an autosave file into an autocad file when simply changing the extension doesnt seem to do it?
Thanks.
Apr 5, 05 2:39 pm
el jeffe
have you tried using the recover drawing feature inside ACAD?
Apr 5, 05 3:20 pm  ·
ArchAngel
Try beginning with a new file then Insert>Block>Browse>AutoSave.dwg....then save as the intended file.
If that doesnt work nothing will.
Apr 5, 05 3:26 pm  ·
Pimp Minister Pete Nice
Or "Alt+F4" to solve your problem...easy
Apr 5, 05 3:30 pm  ·
change the name of the file to something proper...not like '$$$autosave.dwg'
there must also be a *.bk1 file somewhere - thats also a backup file..run a search on the comp for *.bk* files, and try open the most recent one, after renaming it to *.dwg
Apr 5, 05 3:39 pm  ·
siggers
My autosaves all end in sv$ - so try searching for them? I also find that you have to turn "search for hidden files" on sometimes.
good luck!
Apr 5, 05 4:50 pm  ·
