I have a question about of what wall assembly I can use to a building without side setbacks with a building adjacent on the property line. we can't get to a consensus if the building can be on the property line or not. it's a steel frame building. How's the connection with the front wall with insulation on the outside?
What solutions have you come up with so far or did you just immediately jump to the internets to save the day? This is not a simple detail and there is literally no possible way anyone can answer without a shit-ton more context. Stop being so lazy and do the leg work yourself instead of relying on internet forums for your homework. (hint... someone else with an identical question posted in the forums last week. Dig it out if you want a bread crumb trail).
I'm designing a major renovation to a home in a nearby city, including adding continuous exterior insulation and new cladding. The city is infamously strict and complicated when it comes to permitting, but their zoning ordinance is not clear on what setbacks are measured to, just "the wall." The head of the permitting department told me that they have allowed exterior insulation to project into the setback on renovations but that they did not have guidance for how much insulation is too much. I usually do super-insulated homes, with as much as 12" of exterior insulation, but in this case I'm only using enough to meet the 2021 IECC.
For a new building I'm sure they would require all wall elements to be clear of the setback line. Different municipalities have different approaches for roof overhangs; some allow them to project into the setback while others don't.
Jan 22, 23 1:55 pm ·
Wall Assembly with continuous insulation
HI all,
You need to read the jurisdictions regulations as well as the building code. It's all written out.
