Toilet for LGBT and Universal toilet is the same?
Vendetta
If similar why LGBT need unisex/ all gender toilet?
Nov 7, 22 7:14 am
Maybe? Could you try and rephrase in a more confusing way?
Nov 7, 22 8:38 am  ·
could you clarify what you're asking?  uses for an accessible toilet stall with a single water closet and lav?
Nov 7, 22 8:55 am  ·
Vendetta
like this
there is a toilet for special need, is it need to prepare toilet for LGBT?
so, in this case -is it mean universal toilet is enought for LGBT?
Thank you
Nov 7, 22 9:33 am  ·
Is it not your job to know this? If not, ask the client to hire someone more competent who does not crowd-source basic code questions. Also worth noting, codes vary greatly across cities/states/countries/etc... Your question is so vague and ignorant that's it's more sad than comical.
Nov 7, 22 9:37 am  ·
Also, 6 plumbing fixtures for men vs 3 for women? In what fucked-up country is this even legal?
Nov 7, 22 9:38 am  ·
poop876
Non, it would be legal in the U.S.
Nov 10, 22 10:14 am  ·
To the OP, listen to poop. There is a joke in here somewhere . . .
Nov 10, 22 10:38 am  ·
^really? occupancy count for plumbing fixtures assumes 50/50 M/F ratio unless you really have a specific need not too. Our code typically favours slightly higher fixture reqs for F washrooms in public occupancies so it's usually like 3m for 4f... never seen a situation that would allow 6m-3f .
Nov 10, 22 10:39 am  ·
poop876
code minimum or requirement vs. what client wants or needs is a little different! As long as you meet the code requirement, you can go more. In addition the code does allow the distribution of sexes to be other than 50%. So yeah, it would be legal to have different fixture counts for M/F.
Nov 10, 22 10:48 am  ·
To be fair you're both correct depending on the occupancy. If you're in an A occupancy then you need more fixtures for female occupants. Everything else is a 50/50 split between the genders.
Nov 10, 22 10:54 am  ·
Vendetta
Nov 7, 22 10:29 am  ·
50 different genders require 50 different toilets.
Nov 7, 22 11:19 am  ·
Let a hundred toilets bloom!
Nov 7, 22 12:26 pm  ·
Gender and toilets: both constructs. Volunteer and opinions: both dumb.
Nov 7, 22 12:28 pm  ·
What about fractional genders?
Nov 7, 22 1:28 pm  ·
eww, blooming toilets
Nov 7, 22 2:46 pm  ·
square.
as a lover of the free market, you should be salivating at all of the options provided
Nov 7, 22 2:47 pm  ·
Just one big open pit. Array the perimeter of 'the pit' with foot pedestals and grab bars. Gender neutral and eco friendly.
Nov 9, 22 10:39 am  ·
Almosthip
I'm from Alberta so I want Freedom Toilets
Nov 9, 22 10:44 am  ·
Are those like Freedom Fries?
Nov 9, 22 10:56 am  ·
Almosthip
Its where Freedom fries end up
Nov 9, 22 11:17 am  ·
