Either learn how to do it properly from qualified professional who has experienced with Manual J (or any reputable educational source) or you hire a consultant.
While I have a PDF of 7th Edition. I have the 8th Edition of Manual J. If you work residential projects, it is fairly standard stuff. Although, if you have the manual, you have the equations, you can make an Excel spreadsheet to work the calcs if you need to. You need to possess some basic math skills. Stuff, I would be doing by hand if the building official is a stickler for manually showing the math which a building official we had was a stickler for.
Manual J Chart?
My permit application for a small residential addition was denied by the building department.
Among the items I need to address, they want me to provide a "Manual J Chart" which I guess is a heating and cooling calculation.
Have any of you done that before? And is there an easy way to do it?
Thanks,
Mookey
you need to hire someone that can do the reports.
About as easy as it gets
Hire a guy named Manuel J. to install the HVAC and I'd call it good enough.
I prefer his brother, Stephen P.
you don’t know how to use the three seashells?
Who was that to?
To John Spartan, obviously.
I knew the reference's origin. The question was what was the point you were trying to make or not.
Nope. I don’t even know anyone named Manuel J. But I did stay at a holiday in last night.
Preparations A thru G were a complete failure so we shall call this "Preparation H."
