Note Column and bubbles
petewilson
Anyone out there work for a firm that uses note columns and bubbles on their sheets. I have come across some drawings over the years that have those and I know REVIT can do it. Makes sense to some extent in the fact that you only have to change one item, ie in the note column. Otherwise if you make a change you have to hunt down all of those notes and make those changes numerous times.
Nov 29, 21 7:23 am
Yes, Revit does this. It's called Note Block, under schedules.
Nov 29, 21 8:05 am  ·
petewilson
Does your firm use it?
Nov 29, 21 10:47 am  ·
Yes. Although I'd prefer to use the keynote system, and not this.
Nov 29, 21 11:07 am  ·
Almosthip
Yes we use them.  We also use keynotes
Nov 29, 21 12:44 pm  ·
