Hand drawn plan scanned PDF file scale is incorrect
MS90
Hello,
Is there a method to scan hand a drawn plan  to PDF and keep the scale correct(as per the original hand drawn scale). I noticed that scanned full size drawings are losing their initial scale (a little off compare to original drawings) .  I usually scale drawings in AutoCAD model space,  this time i just  need to create a duplicate of the hand drawn plan. Any help and advise would be greatly appreciated for this workflow.
Nov 15, 21 3:10 pm
WTF are you talking about?
Nov 15, 21 3:13 pm  ·
MS90
Is my question too confusing for you?
Nov 15, 21 5:33 pm  ·
joseffischer
your scanner/software/PC setup must be messed up somewhere, it should be scanning exact.
Nov 15, 21 3:18 pm  ·
never happened, nowhere.
Nov 15, 21 3:35 pm  ·
Always happened, everywhere I worked. I suppose the scans could be off by 1/256" but at that point it's not noticeable with line thicknesses when scaling.
Hence why you don't scale drawings.  :)
Nov 15, 21 3:53 pm  ·
"A little off" is un-fixable, it's the way scanners work, they distort the image because the paper is moving and not always at the same speed/direction - if you scale one axis correctly, the other will be off.
Odd. I've never had an issue with scanners like this. Guess ours have always been calibrated correctly.
Nov 15, 21 3:51 pm  ·
I guess you also don't believe paper has shrinkage and expansion depending on humidity and temp. go scan a 30 yr old set of plans and let me know.
Nov 16, 21 10:33 am  ·
Oh I know that paper will shrink and expand. Just like I know that a properly calibrated scanner won't be off enough to make a difference. Sure the scan may be off a wee bit - no more that the margin of error that line weights create. Hence why you don't scale drawings.
Nov 16, 21 10:43 am  ·
Fortunately, scale and dimensions are just estimates anyway.
120 Construction funnies ideas in 2021 | funny pictures, construction  fails, you had one job
Nov 15, 21 4:47 pm  ·
Funny how we always tell contractors not to scale the drawings, then don't listen to our own advice...
Nov 15, 21 5:48 pm  ·
4  ·
The trick is to scan your scale. Then print it out and use it to measure the PDF.
Nov 15, 21 6:38 pm  ·
6  ·
Seriously, how hard can this be? Alternatively, scan it, bring it into Photoshop / AutoCAD / Revit/ sketchup / anything that allows you to resize a drawing. Then print. This is assuming the scale is actually off in the first place. I think copiers might resize things slightly but not scanners. Flatbed would be best.
Nov 15, 21 8:15 pm  ·
reallynotmyname
Yes, flatbed is the best thing to use. It is possible for automatic feeders and rollers to stretch a scanned image, albeit slightly. You can find it discussed on manufacturer support sites for Canon, HP, etc.
Nov 16, 21 9:45 am  ·
just import the image into cad, do a ref scale, plot to paper size, and print…
Nov 16, 21 9:49 am  ·
pamp
This. Just draw a graphic scale on your sketch first.
Nov 16, 21 10:55 pm  ·
Just scan the drawing with a banana at the same time.  That way you can always know the scale.
Nov 16, 21 11:12 am  ·
5  ·
whistler
or a ruler, or am I just being too obvious!
Nov 16, 21 5:06 pm  ·
whistler
or better yet a banana with a hand drawn scale on it! Sharpies work great!
Nov 16, 21 5:07 pm  ·
